It is currently Fri Nov 06, 2026 7:26 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Dual Batterys on 2011 A22
PostPosted: Mon Jun 06, 2011 8:49 am
I picked up my 2011 black A22 vandall a couple of weeks ago. It has the battery switch installed but i wanted to know what size battery people are running for the second one. Also how did you hook it up and secure it to the floor. Any help is greatly appreciated.......thanks
 Post subject: Re: Dual Batterys on 2011 A22
PostPosted: Mon Jun 06, 2011 2:34 pm
Just simple strap down brackets on the floor with a strap to secure it (the battery box) right in front of the stock battery box. It should be ran so the Isolator allows you to choose battery 1, battery 2, both, or turn them both off.
Oh...and I ran two identical batteries.
PostPosted: Mon Jun 06, 2011 3:52 pm
I had the same question about my second battery... I was going to build a custom box for both batteries that would take up less space, but I like how the stock box is sealed and secured. I need to find out what box that is so I can order a second one.
As for batteries. I am running Kinetiks 2000 (x2) and pulling my stock starting battery. It has the same rating as my wifes car battery and she is due for a new one. I use both batteries as audio and cranking. I did this with kinetiks in my last boat for 3 years and loved it. You need to decide if you want to just add a battery or replace the original with 2 new ones. I guess the cheapest easiest route would be pick up a marine battery (ie optima blue top) and that as your second battery. It depends on the load from your system.
PostPosted: Thu Jun 09, 2011 7:19 am
thanks for the replies, does anyone have any pictures of their dual battery set up?
PostPosted: Thu Jun 09, 2011 11:57 am
We picked up the Interstate SRM-29 Deep cycle battery to run our stereo. Cheaper than an Optima Blue Top and has a better RC rating. Got a battery box for it off Amazon.com for $15. Total investment was under $150.
PostPosted: Sat Jun 11, 2011 8:15 pm
We also went with an Interstate battery (SRM-27). Just used a battery box with a strap. We also added a prosport 12 dual bank battery charger. It's nice to be able to just plug it in at night and know the batteries will stay charged. Here is a pic.
PostPosted: Mon Jun 13, 2011 6:45 am
Basically the same setup, different battery charger though.
PostPosted: Mon Jun 13, 2011 9:57 am
I'm running two D3100's from http://www.4xspower.com. Love 'em.
PostPosted: Mon Mar 19, 2012 4:19 pm
I am definately going to add one of these chargers. I have an Optima Blue top (stereo) & stock interstate (starter). Any ideas on the best charger for your dollar?
PostPosted: Mon Mar 19, 2012 5:44 pm
3 Interstate SRM-29 for the stereo and a Interstate group 27 starting battery
