It is currently Thu Oct 30, 2025 11:10 pm
 Post subject: Surfing behind the A22?
PostPosted: Mon May 02, 2011 4:06 pm
Hello I own a 2011 A22 and I was wondering how the boat needs to be weighted for a solid surf wake I do have the plug and play ballast as well! Thanks!
 Post subject: Re: Surfing behind the A22?
PostPosted: Tue May 03, 2011 7:22 am
Fill the rear on whatever side you are surfing, fill the center tank and go from there. Start at around 10.2mph. We sometimes also fill the front bag and bump the speed up to 11.4mph
PostPosted: Sat May 07, 2011 8:18 am
My wife loves to surf and this is how I do it. If you got some friends to act a ballets, it helps. Or what I do sometimes, is move the rear seat and make it parallel with the left or right rear seat depending on what side your rider surfs on, and I fill a 1,000 pound fat sac and set it on the two seats, and I also got a 500 pound sac in the locker and that will make a very big and long wake to surf on. leave the Wake plate up as well. And that my friends is the max this boat will take. If you setup on the drivers side, and use this much weight, be sure to take notice to the gas cap, don't want water going in there.
PostPosted: Sun May 08, 2011 6:46 pm
Full right + 800lb pnp. Some center and some front pnp. 1000lb sac on the seat. Wedge up. 2 in the boat:
PostPosted: Thu May 19, 2011 8:51 pm
Thank you for all your help gonna try it out this weekend!
Users browsing this forum: No registered users and 130 guests
