It is currently Fri Sep 25, 2026 6:59 pm
 Post subject: Re: Oil Change
PostPosted: Wed Jul 11, 2012 10:54 am
Compcowboy wrote:
What evacuator do you use?
blue point ( tool truck at work ) 100$
otownwake wrote:
Don't you have to let the a certified Axis dealer do the maintenance in order to satisfy the Indmar warranty?
don't think so
PostPosted: Mon Jul 16, 2012 11:16 am
It would be awesome if there was a how-to for changing the oil on the Indmar 335. I'd love to do this at home by myself, instead of driving my boat 45 minutes to the dealer every month. Is there one already?
2011 A20
PostPosted: Mon Jul 16, 2012 12:43 pm
Wow are you retired or live on a lake?! 50 hours/month, I'm lucky to get more than about 70-80 in a season.
2012 A22
PostPosted: Mon Jul 16, 2012 2:41 pm
Haha, I live in Florida within 2 miles of a public boat ramp. I usually go out both Saturday and Sunday for about 8 hours a day. :) Although lately, I only go 1 of the 2 days because I've had stuff to do. But still, 8-9 hours a week at a minimum....can be 16-20 though.
2011 A20
PostPosted: Tue Jul 17, 2012 3:44 pm
Short & Sweet Version: Buy the Pella pump with the used oil storage ball on it that holds about 6 quarts. Suck it right out of the dipstick tube or the capped oil drain tube. Change the filter, replace approx 5.5 quarts of 15-40. You may want to start with 5 quarts or a little under & check the dipstick as you add. That Simple!
PostPosted: Tue Jul 17, 2012 8:23 pm
Nice thanks!
What model filter & where is the oil drain cap?
2011 A20
PostPosted: Wed Jul 18, 2012 5:38 am
I emailed Indmar about the warranty when doing your own oil change.
PostPosted: Wed Jul 18, 2012 7:28 am
Oil filter is a penzoil pz52. If it cant be purchased at the auto parts store have them cross reference it in another brand. The oil drain cap is attached at the front of the engine on the right if you are looking at it from inside the boat. It is a black rubber tube with a key ring type attachment secured to the cap. It is attached through the key ring to a bracket to hold it up. Once you get the key ring off the bracket you may need to use 2 wrenches to unscrew it since it is kinda tight from the factory. I'll try to attached a link to a pic of it. Copy and paste this link to the moomba forum. First 3 pics will give you an idea of what it looks like. FYI. You can also suck the oil out through the dipstick tube.
http://www.moomba.com/msgboard/showthre ... pics-by-Al
PostPosted: Wed Jul 18, 2012 8:50 pm
Is there a procedure for the LS3 anywhere? I'm about 2 hours over the 50 currently and need to get it done...
Axisowners
PostPosted: Thu Jul 19, 2012 8:37 am
Here's a list of compatible replacements for the filter. Much cheaper at an autoparts store than bakes online.
Users browsing this forum: No registered users and 65 guests
