It is currently Sat Aug 08, 2026 9:43 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Wakesurfing without the rope, is it REALLY that hard?! :
PostPosted: Wed May 30, 2012 2:38 am
AJWest wrote:
2011 A22 with platform removed. ...
Thumbnail looks really good, but cant see the movie. "This video is private"
PostPosted: Wed May 30, 2012 7:26 am
Let's try that again
PostPosted: Wed May 30, 2012 8:12 am
very nice, she's rippin' it!
2011 A20
PostPosted: Wed May 30, 2012 9:10 am
Dam that looks great. I Wish there was an easy way to get the swim deck off without a trailer. Is it a bitch to get back into the boat?
PostPosted: Wed May 30, 2012 10:15 am
If I was running the old platform, I'd pull it off, measure it, cut a piece of lexan to fit a footprint much smaller than the factory platform, then attach some nice wood - like teak or something - to the lexan sheet, then screw it to the factory platform mounts and be done with it. Otherwise, I'd mock up a small platform out of cardboard, buy a sheet of fairly thick aluminum, get it cut, get it powdercoated, and then put hydroturf on the top and screw it to the factory platform mounts.
PostPosted: Wed May 30, 2012 10:39 am
AJ how fast where you going in that vid. and what code did you use to embed i tried to embed something a while back and couldn't get it to work
PostPosted: Wed May 30, 2012 12:04 pm
You can use the wedge as a step when it's in the down position. If it can support 1000-1200lbs of down force my little 160lb self should be ok.
PostPosted: Wed May 30, 2012 12:08 pm
I set the cruise on 11.8 when she surfs. To embed a video don't use "quick reply", use "post reply" and there's a "YouTube" button to click on and it tells you which part of the string to copy and paste.
PostPosted: Wed May 30, 2012 12:21 pm
I think I heard some people say the 2011 platform will work well if you smooth out the bottom. Any idea on how to go about doing that? I don't feel like spending $1,300 on the 2012 platform :(
2011 A20
PostPosted: Wed May 30, 2012 10:03 pm
Finally found some time to get this uploaded.
Wakesurfing behind 2011 Axis A22 with 750 lb PnP bag half full in rear, front PnP bag 75% full, center tank full, and Wedge Down. People sitting randomly around the boat... Wake can get much bigger and much cleaner under better circumstances with more patient passengers. Stock swim deck, at 10.8 mph
(I'd be interested in hearing if people are modifying the bottom of the stock platform to clean up the wake ,$1300 is a lot of gas)
http://youtu.be/pWkWM1b4N2k
Zak
Users browsing this forum: Google [Bot] and 22 guests
