It is currently Wed Nov 04, 2026 10:29 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Ballast pics please.
PostPosted: Sun May 20, 2012 12:04 pm
I was thinking the same thing Walter. I actually had to go check my 750s to make sure they were really 750s. Lol
 Post subject: Re: Ballast pics please.
PostPosted: Sun May 20, 2012 12:41 pm
I didn't like the factory install so I changed it up installed a 3 way brass valve so I can choose to fill stock or sac. It still drains threw stock so fillin sac first is pointless but I can fill both at same time.
@walter I question what size they are, but going by measurements they should be 400 but looking at ports on flyhigh website they look Like 750s so I'm not sure. I would be pleasantly surprised if they are 750s
PostPosted: Sun May 20, 2012 4:15 pm
starboard side, 750's empty. they lay completely flat and take-up almost no storage. sorry, no full pics yet.
PostPosted: Sun May 20, 2012 4:18 pm
I bet they are the 750, my 400's when completely full sitting flat on the floor have about 6-10" clearance to the lip under the door, yours is touching and it's pushing against the divider wall pretty good, mine doesn't take up near the space that picture shows.
PostPosted: Sun May 20, 2012 5:08 pm
these are for you AJ, you can cram a bunch of crap in the lockers, 1 surf board, 1 kneeboard, 1 wake skate, 1 pair of old hustler trick skis, 1 pair of 172cm skis, 1 slalom ski, 2 full size tubes (deflated of course), 5 life jackets, 1 rope, 1 anchor and rope, 2 buoys, I probably could have put more in there but I was running out of stuff and didn't want to start taking off bindings.
PostPosted: Sun May 20, 2012 5:09 pm
more
PostPosted: Sun May 20, 2012 5:10 pm
more
PostPosted: Sun May 20, 2012 5:15 pm
you can get quite a bit in there, just have to hold your tongue the right way
I was bored today and decided to fill up the front bag on top of the seat just to see what it would look like, here ya go,
supposed to be 950 Lbs when full, it took forever to fill up.
PostPosted: Sun May 20, 2012 5:41 pm
I got an extra 750 and tsunami pump just for laying on bow or surfing. The new sacs come with a cap you can bleed the air out without removing them. Can't wait to try it out- should make the wake sweet spot a little longer.
PostPosted: Sun May 20, 2012 7:14 pm
Is there any way to know for sure? It would make since if they where 750s cause Friday when I saced it out it felt like I didn't have enough bow weight
Users browsing this forum: Google [Bot] and 16 guests
