It is currently Sat Sep 13, 2025 8:37 am
 Post subject: Axis A22 2015 - Service Required Intermittent
PostPosted: Tue May 17, 2022 4:44 am
HI All
Boat type - A22 Axis 2015 - 5.7 Monsoon
Axis GDIS Info ver1.5 date 02/06/2014
ECM: SPN 441 FMI 15
ECM: SPN 442 FMI 15
In short I live in South Africa and there is two of us with exactly the same issue listed below. Also dealer support extremely poor
We receive a service required alarm and then boat goes into limp mode. turning the boat off and on again clears alarm and boat operational again.
Some forums advise its a software upgrade required but seems that related to different engine. Impeller has been changed.
Seems to be when boat in idle the temp increases and the service alarm might be to sensative.
Any feedback of someone in States with same issue and how they solved will be appreciated!
 Post subject: Re: Axis A22 2015 - Service Required Intermittent
PostPosted: Tue May 17, 2022 5:00 am
I’m the other guy. Waiting for some feedback from boating international in JHB South Africa. So far they have not helped with the error code.
PostPosted: Mon Jul 18, 2022 1:37 pm
I would contact Malibu direct i.e . technical service, customer service etc.
PostPosted: Tue Jul 19, 2022 12:59 pm
I would reach out to Malibu and see if someone can give you an ideal on a fix. They might be able to determine if a software update would help.
