It is currently Wed Oct 29, 2025 2:43 pm
[ 4 posts ] |
tlendvay
Post subject: increased center bilge output after a few hours of surfing Posted: Thu Aug 13, 2020 10:21 pm |
Do I have a leak in the ballast bags?
Surfinyeti
Post subject: Re: increased center bilge output after a few hours of surfi Posted: Fri Apr 30, 2021 10:30 pm |
Do your rear cup holders have holes in the bottom?
I put electrical tape over the holes and it helped a bunch!!
admin
Post subject: Re: increased center bilge output after a few hours of surfi Posted: Mon Sep 27, 2021 2:01 pm |
| Site Admin |
I noticed that my bilge will come on during a day of surfing. Id check around and see if you have any leaks from the ballast bags or anything around the engine area. If you have a big issue your pump would probably have a hard time keeping up.
AKNIKLS
Post subject: Re: increased center bilge output after a few hours of surfi Posted: Thu Feb 03, 2022 4:50 pm |
I had the same issue. After a day of trying to find where it was coming from, I found it coming from under the rub rails. There must be a section of separation where the two molds come together. Check to see if the carpet in the rear lockers is wet. Definitely going to be an off season fix.
[ 4 posts ] |
Users browsing this forum: No registered users and 58 guests |
