It is currently Wed Oct 29, 2025 2:48 pm
 Post subject: increased center bilge output after a few hours of surfing
PostPosted: Thu Aug 13, 2020 10:21 pm
Do I have a leak in the ballast bags?
 Post subject: Re: increased center bilge output after a few hours of surfi
PostPosted: Fri Apr 30, 2021 10:30 pm
Do your rear cup holders have holes in the bottom?
I put electrical tape over the holes and it helped a bunch!!
PostPosted: Mon Sep 27, 2021 2:01 pm
I noticed that my bilge will come on during a day of surfing. Id check around and see if you have any leaks from the ballast bags or anything around the engine area. If you have a big issue your pump would probably have a hard time keeping up.
PostPosted: Thu Feb 03, 2022 4:50 pm
I had the same issue. After a day of trying to find where it was coming from, I found it coming from under the rub rails. There must be a section of separation where the two molds come together. Check to see if the carpet in the rear lockers is wet. Definitely going to be an off season fix.
