It is currently Thu Nov 05, 2026 1:38 pm
[ 2 posts ] |
Shane
Post subject: MIL FAULT CODE 4237 Posted: Wed Aug 05, 2020 7:56 pm |
Wondering if anyone has had this fault code come up and what was done to fix it. When I look it up is says Long-term Fuel Trim – Bank 1. I called a dealer to get their take on it and they said it told them it was a misfire to do plugs, wires, cap and rotor.... but... the boat doesn’t have a cap and rotor... makes me question them a little. I plan to do plugs and wires and test coils. But would like to hear if anyone else has had this code pop up and what was done. Thanks!
MuchoAloha
Post subject: Re: MIL FAULT CODE 4237 Posted: Tue Aug 03, 2021 11:44 am |
I know it's been a while since you posted. The is the downstream O2 sensor on your cat on the starboard side (I think its that side)... I had same prob but with 4237 and 4239 which is both sides. I swapped plug, ran new gas with a bottle of Seafoam and code never came back up. Most boat techs can plug up and tell you want your trim %s are running at, they need to be no more than +10% or -10%... a good range is 5-7% (positive or negative is fine.)
Other reason could be bad sensor or fuel pump is struggling. Or, possibly manifold overheating and causing issues with sensor.
[ 2 posts ] |
Users browsing this forum: No registered users and 28 guests |
