It is currently Sun Aug 09, 2026 4:54 am
 Post subject: Front sac draining from bottom of boat
PostPosted: Thu Jul 02, 2020 9:21 am
2014 A22, the front sac is draining out the bottom. When I look for the siphon loop, there is one behind the sub and two in the rear. The front sac fills up from the battery area, not behind the sub. Am I missing a siphon loop? I also have a capped hose in the battery area which is odd to me. Thanks for any help.
 Post subject: Re: Front sac draining from bottom of boat
PostPosted: Fri Jul 03, 2020 3:50 pm
My front sac was draining in our 2015 T23. I put a valve in the outflow hose and it would still drain so put one on the inflow hose next to bag and everything works great.
Not sure if that helps but it was easy fix.
2015 T23
PostPosted: Mon Jul 06, 2020 12:34 pm
Same here. I have a shutoff valve in the fill and drain lines of the front sac. If I don't close them, it drains itself. Just too much water too high in the boat. It is just pushed through the pumps by gravity.
2014 A22
PostPosted: Fri Jul 10, 2020 9:07 am
Well, my 2014 A22 does not and never has drained out the bottom. No valves and no hassles.
I have not looked, and the boat is 200 miles away at the river, but I guess I have always assumed there was a check valve in the line. But I can say forsure that mine does not self drain
