It is currently Mon Sep 21, 2026 9:45 pm
 Post subject: loading and unloading
PostPosted: Wed Apr 25, 2012 10:16 pm
Hey guys... i know this is a total noob question (mainly because i am a total noob) but i was just curious about how everybody is loading and unloading their boat. the dealer didnt really go in depth on the subject so if somebody wouldnt mind taking a quick video and maybe explainig any little tips or tricks they have picked up that would be awesome.
thanks
kohlieo
 Post subject: Re: loading and unloading
PostPosted: Wed Apr 25, 2012 10:43 pm
There's a good discussion on the topic here (with a video) - http://www.themalibucrew.com/forums/ind ... n-trailer/. And another video - http://www.youtube.com/watch?v=n1ESbZTXAO0 - this ones a bit general, but it may help you built a checklist.
For our first boat I carried a checklist of all the steps (plugs, blower, straps, etc) just to make sure I did everything right.
I also aways keep the winch strap and safety chain on when the boat isn't in the water. I see some going down the ramp without the strap (and it almost seems to be the case in the one video on the Malibu thread), but I've also helped someone push their boat on because it slipped off too soon.
PostPosted: Thu Apr 26, 2012 12:14 am
good discussion as referenced above by dave. I have read that and am in the super minority when loading and unloading.
This is what I do, for what it's worth.
Unloading:
prepare area (if you have one). Turn on battery, turn on blower, check that both drain plugs are in (transom and t handle midship), unhook all straps.
Everybody in boat except driver of tow vehicle: back down ramp slowly and smoothly until trailer fenders are below water line a few inches, driver then stops quickly, boat will smoothly slide off trailer with little rubbing on bunks. Start the boat and continue in reverse. Turn boat around and idle way away from launch ramp to leave room for everyone else. Float, with engine at idle warming up while you listen to tunes, fill up ballast, put up bimini, etc. When boat driver reaches dock, go get them and picked up from your bow... then go shred.
Loading:
Drop off vehicle driver only and then drive far away from dock and wait. Use this time to finish emptying ballast, ice chests, putting bimini away, cleaning up. When you see your truck and trailer at top of ramp, idle towards it. Driver sinks trailer so trailer fenders are a few inches under water but leaves tranny in reverse. Idle boat slowly onto trailer until it stops. The trailer will center the boat on the bunks. Throttle boat forward with steering wheel straight until the front U-bolt hits the roller. If you are at half throttle and the boat will not slide anymore, then keep throttle in that position and have driver of truck SLOWLY and smoothly back up until your boat hits the roller. Truck stops, put the boat trans in neutral, if the boat does not slide back at all*, then turn off boat, truck then SLOWLY and SMOOTHLY drives up the ramp to the "wipe down" area. Connect all your straps (bow and transom-if you have those) Everyone on boat gets themselves and all their crap out, wipes down boat and goes home :)
I have a lot of bow lead so I have to keep a little forward throttle as the truck driver begins pulling out. As soon as the trailer tires get out of water I throw it in neutral and cut the engine before the sea-water pickup hole is out of the water, even though there is a lot of water keeping that sea water impeller wet.
As a new boat owner, I would not load your boat the way I do it, but I would definitely unload it the same way as I do. No need to pull your boat off the trailer in reverse with a cold, under lubricated motor that has been running for a few seconds... plus there is no need for that, just let it slide off.
PostPosted: Thu Apr 26, 2012 2:42 am
Thats awesome guys, thank you so much for the quick response. The thread on the malibu crew was exactly what I was looking for.
PostPosted: Thu Apr 26, 2012 8:07 am
Plus having a girlfriend/wife that likes unloading and loading the boat makes boating a lot less of a hassle at the ramp/dock and it's just sexy to see my girl handling the Axis with confidence. Happy boating
