|  | It is currently Fri Oct 31, 2025 3:46 am
		|     | Page 1 of 1
 | [ 2 posts ] |  |
			| Author | Message |
			| buffaxis |
					|  Post subject: Acme 2773 prop vs 2419  Posted:  Fri May 03, 2019 5:34 am  |  |
					| Team Axis |  Joined: Wed May 11, 2016 5:45 pm
					| I have a 2014 t22 with a 2419 that needs repair.. I called acme and they recommended a 2773 prop its the same diameter of the 2419 which is a 15-12 and the 2773 is a 15-13.
 does anyone run the 2773 on their boat?
 They mentioned that the 2419 might be too aggressive and run at a higher RPM / and not needed I have the plug and play ballast with 800 bags in the rear...
 any thoughts would be great..
			| Top |   |
			| 80AMT23 |
					|  Post subject: Re: Acme 2773 prop vs 2419  Posted:  Sun May 05, 2019 4:09 pm  |  |
					| Team Axis |  Joined: Thu Jun 16, 2016 12:34 pm
					| It's up to you whether it's too aggressive, the 2773 will run lower RPM than the 2419 but it will also not spin up the motor as high of RPM which may mean you lose power getting on plane, but I found the 2419 put the RPM way to high out of the hole and it went past the peak powerband of the engine. A lot of people like the 2773 as a good balance. _________________
			| Top |   |
		|     | Page 1 of 1
 | [ 2 posts ] |  |
		| Who is online |
		| Users browsing this forum: No registered users and 144 guests |
	|  | You cannot post new topics in this forum You cannot reply to topics in this forum
