It is currently Fri Oct 17, 2025 10:07 am
 Post subject: T22 2017 ACC switch - where are the wires these switches pow
PostPosted: Sat Dec 22, 2018 5:33 pm
Hi
I am going to wire up an air pump as well as a transom shower pump, that I will turn on and off via the ACC switches on the secondary switch pad in my T22.
I cannot locate the wires within the boat to do this?
Has anyone played around with this?
Malibu are very reluctant to give out any documentation.
 Post subject: Re: T22 2017 ACC switch - where are the wires these switches
PostPosted: Sun Dec 23, 2018 11:43 am
On the older models with switches you had to connect directly to the switch, i would assume the pad is about the same way unless there are wires bundled to the side under the dash
PostPosted: Sun Dec 23, 2018 3:07 pm
Thanks,
With the new axis boats, the switch pad plugs into a secondary power module. And there is a large plug going into the back of the power module and this has A bunch of coloured wires coming out. They all disappear into the boat.
Where they end up is anyone’s guess! :-)
PostPosted: Mon Dec 24, 2018 11:29 am
Ah yea sorry cant help you there, surely someone on here know if you are on facebook find the malibu & axis boat owners page you will get more answers there than on here
PostPosted: Mon Jan 07, 2019 8:40 pm
the pad switch activate a output on the power module on the left side of the steering it fuse 5 amp so you will have to put a relay and a breaker or a fuse to active your accessorize i am on a project like this if you give me a week or two i will give you the pin out, i am searching to find what connector malibu used its commun just not shure yet .
PostPosted: Sun Jan 20, 2019 7:00 pm
i found the pin out if someone need it
PostPosted: Tue Jan 22, 2019 1:14 pm
So you know how to utilize the extra buttons on the 2017+ axis boats? I have a 2017 a20 that id like to use the acc buttons. Email me @ addonbuilders @ gmail if you have any info on how to do it. Thanks
PostPosted: Tue Jan 22, 2019 2:38 pm
Please put it in the thread. These get searched later and having the answer would obviously be huge for the future user.
________
PostPosted: Sun Jan 27, 2019 8:43 pm
the accessory switch control the MUX power module it on the left side of steering you will have to put 2 new connector in the plug and fron there drive a relay the module its good to just 5 amp
PostPosted: Sun Jan 27, 2019 8:48 pm
i have all the picture but how i post it help
Users browsing this forum: Google [Bot] and 25 guests
