It is currently Wed Oct 14, 2026 3:30 pm
 Post subject: 2014-17 T22 Bow Ballast plug and play details
PostPosted: Fri Dec 28, 2018 1:03 pm
I am going to permanently plumb in my bow bag.
Both cables from the switch for the inflow and drain pumps are under the Tdrain cap next to the centre tank.
I will put the inflow pump on the Tdrain thru hull rather than making a new thru hull (unless someone can convince me otherwise)
Can someone tell me the location of the drain pump in their boat? Is it up the front near bag, under the steering wheel console or near centre tank running long tubes??
Thanks
 Post subject: Re: 2014-17 T22 Bow Ballast plug and play details
PostPosted: Mon Dec 31, 2018 9:06 am
I'm a bit confused, is this a pnp bag under the bow seats, or are you trying to add a new on-seat triangle bag in the bow?
Regardless, when I added a bag I chose to add a reversible pump on a new thru hull. It allowed me to choose the thru hull size - obviously larger than the t-handle drain fitting - and retain the midship drainage. I paid a boat garage 20$ to drill the hole, I provided a new hole saw. After seeing it done a few times, it really isn't that big of a deal. Once you get past the idea of putting a hole in a boat it really isn't difficult to manage.
Users browsing this forum: No registered users and 61 guests
