It is currently Wed Feb 25, 2026 7:25 am
 Post subject: Surfgate actuator upgrade to the faster one???
PostPosted: Thu Apr 27, 2017 5:22 am
I have 2015 axis T 23 that has the slower older style surfgate actuators. Can those be taken off and swapped out for the newer surfgate actuators that are faster?
Is any programming required to make it work?
Are the connections and wiring the same?
Is it worth the upgrade?
Rob
 Post subject: Re: Surfgate actuator upgrade to the faster one???
PostPosted: Fri Apr 28, 2017 9:40 am
can someone with a 2016 post some pics of the newer actuator and also find the manufacturer and part number listed on it? From that Ill do some research and see what I can come up with. Im sure that it would be a nice upgrade once our factory actuators break over time.
PostPosted: Sun Aug 12, 2018 7:28 pm
Anyone?
PostPosted: Sun Aug 12, 2018 9:52 pm
From a 2017 A22.
PostPosted: Mon Aug 13, 2018 11:49 am
What is the speed of the newer actuators compared to the older style on my 2015?
PostPosted: Mon Aug 13, 2018 3:49 pm
I can’t say much about the old ones but mine might take a full second to switch from side to side. Easily fast enough to do a rope less transfer.
PostPosted: Wed Sep 26, 2018 8:41 am
Just say light years faster, I have the slow ones and doing transfers ropeless is hard work, surfed the new ones and there is no comparison. Now remember this, bet yours are indestructible and may never break because that is the two year debugged Malibu original SG actuators
PostPosted: Thu Jan 17, 2019 8:50 am
I timed my gates very recently on transfers and it was a full 8 seconds with the use of steering into the wave formation to help, miserable slow
PostPosted: Sat Jan 19, 2019 8:04 am
Just curious if you found a price on the new actuator and where you purchased them?
Jim Fuller
Lake Keowee, SC
2014 Axis A24
Boat Name: Who's Next
PostPosted: Mon Feb 04, 2019 7:30 pm
I have a pair taken off a 2017 T23. Same Parker as pictured above EHA 649221.
