It is currently Sat Nov 08, 2025 11:40 am
 Post subject: Sluggish Acceleration 2013 A22
PostPosted: Tue Aug 07, 2018 10:28 am
Hi there, I have a 2013 A22 with about 250 hours on it. I’ve owned the boat since new, and overall the boat has run really well, and I’ve had almost no issues with it.
Last weekend I noticed that the acceleration was sluggish, but once up to speed it ran fine. There are no warnings or codes being thrown, so I wanted to get your thoughts on what I should look for before I take it to the shop.
Could this be bad gas or water in the gas?
I am not very mechanically inclined, so if it’s not a simple fix, I will likely take it in to the shop.
Thanks.
 Post subject: Re: Sluggish Acceleration 2013 A22
PostPosted: Tue Aug 07, 2018 11:35 am
What motor?
When was the last time it had a full tune up?
PostPosted: Tue Aug 07, 2018 11:40 am
Monsoon 350HP 5.7L Cat
Gets serviced once a year (winterization, oil change, etc) in the fall. Last service was Fall of 2017, with a spring run up in may 2018.
PostPosted: Tue Aug 07, 2018 1:50 pm
Hmmm.
Other than a full tune up I suspect you may need to get it to a dealer to have them look at it with Diacom.
