It is currently Sun Oct 18, 2026 3:51 am
 Post subject: ACME 1235 4 Blade 14.5" x 14.25" Propeller - $350
PostPosted: Fri Jul 20, 2018 1:02 pm
The ACME 1235 4 Blade 14.5" x 14.25" Propeller offers more surface area than comparable 3 blade propellers which means a more efficient transmission of power, higher fuel economy, and more consistent speeds. Thanks to ACME's continued devotion to push the ski and wakeboard boat propeller industry to new heights inboard props are helping ski and wakeboard boats achieve performances never before seen.
Prior to 1999, ski and wakeboard boat propellers were cast from molds, a process that offered little precision and had severe limitations for the size and shape of the blades. The result was inefficient props with small blade surface area and poor balance which caused vibration in the boat drive train. However, all that changed when ACME introduced CNC machining to the inboard propeller industry. By precision machining its waterski and wakeboard boat propellers ACME is now able to hold tolerances and achieve accuracies never before seen in the inboard propeller industry.
What does that mean for you? The ACME 1235 4 Blade Propeller will perform up to and surpass the standards you expect from the moment you pull it out of the box and put it on your boat.
I can ship it for $40
 Post subject: Re: ACME 1235 4 Blade 14.5" x 14.25" Propeller - $350
PostPosted: Mon Jul 23, 2018 8:07 am
Here are some pictures.
PostPosted: Thu Jul 26, 2018 6:22 am
Sold
