It is currently Sat Sep 13, 2025 12:18 pm
 Post subject: T22 2018 can't fill starboard hard tank - HELP
PostPosted: Wed Jul 04, 2018 6:57 am
Like the subject says, it sounds like there's a clog (I can hear the motor pitch is wrong) no idea how to go about finding it or where to look any help is appreciated.
First Boat - Tiny AlumaCraft w/ 8hp Johnson
---- Nothing -----
Last Boat - 2016 Four Winns H180RS --- RIP 1/25/2018
New Boat - 2018 Axis T22!!!!!!!!!!!!!!!
 Post subject: Re: T22 2018 can't fill starboard hard tank - HELP
PostPosted: Wed Jul 04, 2018 7:50 am
Slide your rear bench seat forward, pull the vdrive cover. You will see the fill pump mounted to the hull with a valve . Take the screw out of the blue collar and remove the little blue insert so you can twist the collar. Pull the pump apart and this will give you a full visual of impeller and fill pick up hole.
PostPosted: Wed Jul 04, 2018 10:29 am
Do I need any special tools my boats at the lake and wanted to make sure I took with me what I would need.
---- Nothing -----
PostPosted: Wed Jul 04, 2018 12:59 pm
Just a Phillips screwdriver
PostPosted: Sun Jul 08, 2018 3:21 pm
We a
had a similar problem with our 18 A24, it ended up being a kinked hose between the pump and the tank. It came from the factory that way.
PostPosted: Fri Jul 13, 2018 8:37 pm
Check your pickups there are 4 under the boat they are black they can clog with weeds ...
Users browsing this forum: No registered users and 79 guests
