It is currently Sun Jul 26, 2026 3:47 am
 Post subject: What oil?? Rotella no longer approved ?
PostPosted: Sun Mar 25, 2018 4:27 pm
Was using rotella 15/40 in my axis boat last 4 yrs but just read about how they changed the classification on the jugs and it no longer covers what it used to on triple-T
Now they have t4 5 etc
Any input?
 Post subject: Re: What oil?? Rotella no longer approved ?
PostPosted: Sun Mar 25, 2018 6:50 pm
How about shaeffer or mobil delvac?
PostPosted: Sun Mar 25, 2018 7:39 pm
I’ve been running chevron delo 400 since the rotella switch.
PostPosted: Mon Mar 26, 2018 6:59 am
Can we not use Shell Rotella T4?
2015 T23
PostPosted: Mon Mar 26, 2018 9:11 pm
No, haven’t been able to for awhile.
More info in this thread. http://www.themalibucrew.com/index.php? ... ent-997183
PostPosted: Tue Mar 27, 2018 5:09 am
If you use Rotella you need to use the full synthetic.
PostPosted: Thu Mar 29, 2018 4:08 pm
Ok so I just switched to the delo 400
All is well for now
Thx
PostPosted: Fri Mar 30, 2018 7:43 am
you have to run the correct Delo oil too.
You want Delo 400 SDE or Rotella T6
PostPosted: Fri Mar 30, 2018 11:34 am
Couple of questions from someone who doesn't know anything about engines.
My dealer did winterize and oil change with the Rotella T4. I assume at this point I don't do a complete oil change until end of season?
So this season when oil gets low do I just keep adding the T4 or can you mix in the Delo 400 SDE?
2015 T23
PostPosted: Fri Mar 30, 2018 12:54 pm
I’m more picky than most, so if it were me when I needed to add oil I would change it all.
Users browsing this forum: Majestic-12 [Bot] and 32 guests
