It is currently Mon Oct 05, 2026 7:39 am
 Post subject: 2011 axis a22 random start issue
PostPosted: Tue Jul 25, 2017 1:15 pm
I have a 2011 axis a22 and I am having a issue with it starting sometimes and others not times not starting. I have replaced the ignition module and coil pack the dizzy cap wires plugs. and I can put a spark tester on it and turn it over and get no spark one sec stop turning it over and turn it over again and it will have spark. once it does start it runs great. I have tested or checked the kill switch the ignition switch and pulled the grounds off the block cleaned and reinstalled them.
also the only thing that seems to not work is the spark I put a fuel gauge on it and it gets pressure the second you turn the switch to the on position.
 Post subject: Re: 2011 axis a22 random start issue
PostPosted: Tue Jul 25, 2017 7:06 pm
Crank position sensor could cause that condition
PostPosted: Thu Jul 27, 2017 1:28 pm
well I changed out the crank position sensor today and it didn't help at all
PostPosted: Thu Jul 27, 2017 5:23 pm
Is it throwing a code?
PostPosted: Fri Jul 28, 2017 7:02 am
Nope no codes
PostPosted: Sun Jan 28, 2018 8:53 am
I had a problem on my 13, the relays had loose connections were they plugged into the fuse block, put a twist in the male end of the relays so they made better contact and haven't had a problem in 2 yrs
