It is currently Sun Nov 02, 2025 4:09 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: OJ 5 Blade
PostPosted: Wed Apr 11, 2012 12:14 pm
AJWest wrote:
Anyone want to chime in on how to get the 5-blade prop off since a c-clamp type puller will not fit. Maybe a little heat and a "massager" (hammer and a piece of wood)?
AJ, I remember reading somewhere here that a member did exactly that to get his off (heat + wood & hammer). Maybe they can comment here.
2011 A20
PostPosted: Wed Apr 11, 2012 12:34 pm
Just found a Walter #2N prop puller on craigslist for cheap cheap cheap. It does 3, 4, and 5 blade props. Be nice to have it just in case.
PostPosted: Wed Apr 11, 2012 3:51 pm
I will say the 1615 came out of the hole quicker for me, but overall I like the OJ Cinco. I needed a backup anyways.
Cheers
PostPosted: Wed Apr 11, 2012 4:38 pm
Johnnydefacto wrote:
otown. NastyA20 went from the 1235 to the cinch, so hopefully he can chime in about the hole shot, he too has an A20 running similar weight, and yes it is reasonable to expect to get on plane with that weight set up. as for lead, the front bow backrest cushion in the center of the bow between the speakers pops off really easy, use a plastic putty knife or ruler the first time. then 3 screws takes off that triangle aluminum axis plate and vinyl backing. this exposes a 6" access hole for the bow light. TONS of room up there for lead. lead-wake bags fit through the hole with a little bit of modifying with a saw. I tried to get my lead up there by coming from the side or middle of bow where the mushroom sack goes, but it was too tight...
Nice I'll give this a try! Thanks a bunch.
2011 A20
