It is currently Fri Nov 21, 2025 12:02 am
 Post subject: Did I purchase the correct spark plugs?
PostPosted: Sun Sep 10, 2017 10:32 am
I have a 2013 axis a 22 . I was reading the owners manual and it specified two different spark plugs, one of which was the MR43LTS. That is the one I purchased and I'm getting ready to replace all eight. I read on line that some suggested that that is only for the non-catalyze engines. I have the monsoon 330. I noticed also that there are gap specifications in the instructions. Will the MR43 LTS work as is or do I need to buy different spark plugs? I have no idea what the standard gap is from the factory. Thank you for any insight.
2013 Axis A22 with soon to be added ballast upgrades for the PNP system. Acme 2315 Prop. Bunch of happy kids!
PostPosted: Mon Sep 11, 2017 9:36 am
Just spoke to Indmar and they stated that I need to use the 41-101. Sure would've been nice if axis would've got the specs correct in the manual
 Post subject: Re: Did I purchase the correct spark plugs?
PostPosted: Wed Sep 27, 2017 9:07 am
I just replaced my spark plugs on my 330 monsoon. 41-101 from any auto parts store will work. mine were 5$ each after rebate. Check the cross reference and see if yours match 41-101. I recommend you buy the 41-101's and take both to your boat, then see if they match physically once you start removing the old ones. It wouldn't be fun to punch a hold through your piston just because the spark plug length was off.
These plugs DO NOT come pre-gapped like more modern spark plugs. i had to bend all mine in to the gap specified in the Indmar manual (.40'). the carbureted ones are gapped to .30'.
2014 Axis A20 Surf Gate
