It is currently Tue Nov 03, 2026 9:36 am
Post new topic Reply to topic  [ 133 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14  Next
 Post subject: Re: T23 ballast setup
PostPosted: Wed Aug 30, 2017 11:43 am
BTW the wake makers engine dividers work very well.
2016 T23, 3600 rear, 400 sides, 1000 bow 2313 Prop
do you know what size are the ones that come with the boat?
PostPosted: Wed Aug 30, 2017 11:45 am
yea i have the engine dividers from my old boat. but these sacs fill up infront of the engine compartment towards the bow, and then fill up a good bit, maybe 6-10" of space left when the door shuts.
PostPosted: Wed Aug 30, 2017 12:30 pm
Please post pictures if possible. I have the 2016T23 unless they changed the setup should be the same. Mine go under the seats abit in the rear as well as fill up the back lockers.
PostPosted: Wed Aug 30, 2017 1:00 pm
sounds the same. do you know the claimed lbs of those?
PostPosted: Wed Aug 30, 2017 4:23 pm
agarabaghi wrote:
Im trying to figure out what size bags i have in the back of my 2017 T23. They are def custom made for this boat as they look kind like an upside down L ? Are these the 1100s?
What brand are they?
PostPosted: Wed Aug 30, 2017 8:35 pm
kaotic818 wrote:
Currently it doesn't completely plane since all we mainly do is surf 10.8-11.2 MPH. Ive added more led today hopefully it planes more. I noticed the 1235 the stock prop was 36-3800 RPM and now the 2313 Prop is max 4k RPM which is cruising speed. I Plan to try to get up to wake boarding speed tomorrow im testing the 2313 still. If im not happy my prop guy will happily exchange it for the 2315.
I run the wedge but i'll try without tomorrow .
Hey kaotic just wondering if any luck with that 2313 prop or did you switch to a 2315?
2016 A22
PostPosted: Thu Aug 31, 2017 6:52 am
I will check next time we are in the boat.
Im starting to believe the dealer now that he said they are 1100s since when running ... 7x 40lbs lead under the 625 sac in the nose, 5x 50lbs lead in the walk way 2x 50lbs in the storage under glove box, wedge, pnp and stock filled with 2 people in the nose and 3 people in the cabin are and she was pushing 4000k rpm at wakeboard speeds and the drone shots were showing a good bit of the front of the boat out of the water. might keep moving weight up front or try with out the wedge.... wake was pumping though!
PostPosted: Thu Aug 31, 2017 6:24 pm
Sorry for late response. The prop works awesome here is a picture. I dont really wakeboard but the wake surf wave is almost chest high on some riders.
21151375_10154973564112914_1242065048858992388_n.jpg [ 101.5 KiB | Viewed 39126 times ]
PostPosted: Tue Sep 05, 2017 10:59 am
Now comes the question, how much difference is there in between the 2313 and 2315? I need to swap out to one or the other.
