It is currently Tue Sep 22, 2026 1:03 am
Post new topic Reply to topic  [ 131 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14  Next
 Post subject: Re: New A24...
PostPosted: Fri Aug 18, 2017 8:16 pm
Allybuck64 wrote:
Lot of good pictures on this listing.
http://www.boattrader.com/listing/2018- ... -103131303
Glovebox is horrible. What happened!?!??
PostPosted: Sat Aug 19, 2017 5:47 am
I wish I had the newer interior but I like my 14 dash and glove box more
PostPosted: Sat Aug 19, 2017 8:10 am
I'm right there with you.. but I also wish I had the power wedge..
PostPosted: Mon Aug 28, 2017 7:47 pm
does the power wedge make that much difference vs the auto set wedge?
PostPosted: Mon Aug 28, 2017 7:57 pm
From what I have heard yes
PostPosted: Tue Aug 29, 2017 7:48 am
so I would assume this makes it more adjustable right? I was surfing with a small crew the other day and my bow bag kept draining causing a good bit of bow rise,
I would think with PW2 you could adjust the wedge to lower the bow some right? instead of dumping water out of the rear?
PostPosted: Tue Aug 29, 2017 8:40 am
So the big benefit of the power wedge, even if you don't like to ride with wedge is that it can go into "Lift Mode" where it goes forward and the foil runs at an angle instead of equal to the water and thus creates lift and lifts the rear of the boat up, offsetting a good amount (unsure of specifics) of the rear ballast allowing you to get on plane with more weight in less time than you would have otherwise. It will then go to the specified position after it gets on plane.
The various wedge positions also change the wake shape and you can play around with which setting you prefer most.
PostPosted: Tue Aug 29, 2017 1:07 pm
so is my computer messing up with the boat builder or is there only 2 gel schemes for the a24? it list four different ones but 2 of them look the same?
looking to design this color scheme or is it a special addition?
http://www.alliancewake.com/wp-content/ ... 90x425.jpg
PostPosted: Tue Aug 29, 2017 3:11 pm
With the A24 they did a hull re-design and now it has the same schemes as the other A series. This was the previous scheme on the last gen A24.
PostPosted: Tue Aug 29, 2017 4:03 pm
Yeah, you'll have to do the Tricked Out option. That was the old tricked out scheme.
2013 A22 Black/Orange - SOLD
Users browsing this forum: Majestic-12 [Bot] and 45 guests
