It is currently Tue Nov 03, 2026 9:37 am
Post new topic Reply to topic  [ 133 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14  Next
 Post subject: Re: T23 ballast setup
PostPosted: Thu Aug 10, 2017 1:06 pm
kaotic818 wrote:
I just bought the PNP 1100's for rear trunks, 2313 prop and have 1000 pounds of led for the bow.
Curious how it rides with empty ballast and 1k lbs of lead in the bow.. my boat would be super low in the nose.
PostPosted: Thu Aug 10, 2017 2:56 pm
With that 2313 prop and your ballast filled (or even partially filled), will your boat get up on plane for wakeboarding speed?
2016 A22
PostPosted: Thu Aug 10, 2017 9:18 pm
Probably without wedge
PostPosted: Thu Aug 10, 2017 9:39 pm
I agree. The bow weight will help plane. 2315 would be a little better though
PostPosted: Fri Aug 18, 2017 8:47 am
My 2016 T23 im running 1100's in the rear as well. I just bought the 2313 prop it doesnt appear to make the wave any better or worse but the RPM's shot up 2-300. How are you guys dealing with the 1100's pushing the motor side panel's in? Im also running about 1000 in ballast and led in the bow and 400 in each side compartment. I also put about 250 extra pounds of led in the back lockers under the PNP bags its helps .
Some of the people i know weight their boat down even more on an Axis T20 or T22 with the 350 motor.
2016 T23, 3600 rear, 400 sides, 1000 bow 2313 Prop
PostPosted: Fri Aug 18, 2017 7:07 pm
How are you guys with the 1100's in the rear trunks dealing with the plastic panels pushing in that protect the motor?
PostPosted: Fri Aug 18, 2017 7:19 pm
Wakemakers sells a kit with 3 pieces of aluminum channel to stiffen up panel.
2013 A22 Black/Orange - SOLD
PostPosted: Sat Aug 19, 2017 12:53 pm
Currently it doesn't completely plane since all we mainly do is surf 10.8-11.2 MPH. Ive added more led today hopefully it planes more. I noticed the 1235 the stock prop was 36-3800 RPM and now the 2313 Prop is max 4k RPM which is cruising speed. I Plan to try to get up to wake boarding speed tomorrow im testing the 2313 still. If im not happy my prop guy will happily exchange it for the 2315.
I run the wedge but i'll try without tomorrow .
PostPosted: Wed Aug 30, 2017 11:36 am
Im trying to figure out what size bags i have in the back of my 2017 T23. They are def custom made for this boat as they look kind like an upside down L ? Are these the 1100s?
PostPosted: Wed Aug 30, 2017 11:42 am
Mine are the same i bought the 1100's they fill the compartment perfectly. But you need to add bow weight to even out the boat so it can plain.
