It is currently Tue Nov 04, 2025 6:38 pm
 Post subject: What type of oil in a t23
PostPosted: Thu Jul 06, 2017 7:58 pm
So as many have mentioned, the T23 seems to like oil. When topping off oil what do you guys use in a 2016 t23. Also should I check levels cold prior to start or after cranking and cut off?
 Post subject: Re: What type of oil in a t23
PostPosted: Thu Jul 06, 2017 8:54 pm
If you live in the south, go with Pennzoil SAE 40, if you're further north and have mornings lower than 60 degrees, stick with 15w40 but you're going to need to top off more often.
PostPosted: Thu Jul 06, 2017 10:54 pm
^THIS
PostPosted: Fri Jul 07, 2017 12:21 pm
Thanks guys. Live in north ga so cold will not be an issue
PostPosted: Fri Jul 07, 2017 4:46 pm
I run Rotella seams to burn less than others.
PostPosted: Fri Jul 07, 2017 6:51 pm
You still use sae 40 weight Gibbs?
PostPosted: Fri Jul 07, 2017 7:05 pm
Yes Ive ran it in my last few boats with no issues. I tried pennzoil in this one but it was using more oil than gas. Went back to rotella
PostPosted: Wed Jul 19, 2017 9:40 pm
My dealer recommended I switch from the 15w40 to the Penzoil SEA 40. I have a 2016 T23. I have put 40 hours on this summer and have added 4 quarts. The service manager was telling me they are starting to recommend oil changes every 30 hours which seems a bit crazy to me. I didn't have to put anything in for the first 20 hours this summer. I have to check the oil every time before I take the boat out and now keep a quart on the boat just in case.
How much are other people needing to put in? My last boat (not an Axis) would go all summer without an oil change or having to add oil. I realize every boat is different but this is the one issue that bothers me about my Axis.
I boat in North Carolina.
PostPosted: Wed Jul 19, 2017 10:20 pm
I have a 2016 A20 with the 350 and have to add 1 quart every 10 hrs. I've had a 05 MC X2 and 06 xstar that never burned oil.
Users browsing this forum: No registered users and 61 guests
