It is currently Fri Nov 13, 2026 8:40 am
 Post subject: Ballast pumps
PostPosted: Tue Jun 27, 2017 12:44 pm
I think my ballast pumps went out-but I can hear them run when it's supposed to be draining? Has anyone had this problem? Also are there better pumps to replace them?
 Post subject: Re: Ballast pumps
PostPosted: Tue Jun 27, 2017 12:53 pm
They are most likely plugged up with debri. They are easy to take a part and check. Are they the piranha 1100's?
PostPosted: Tue Jun 27, 2017 1:01 pm
Not sure I just got the boat-2nd time out and now I'm on duty. Do they all fill from the same port? I'm upgrading the ballast with the wake makers plug and play to 350 summo bags also. Just pull the pumps and clean them?
PostPosted: Tue Jun 27, 2017 1:04 pm
What year and model boat?
PostPosted: Tue Jun 27, 2017 1:09 pm
2012 a20
PostPosted: Tue Jun 27, 2017 1:20 pm
Stewy209 wrote:
2012 a20
Unless things changed i believe Axis has always ran 4 fill pumps, each having it's own through hole from bottom of boat and 4 drain pumps. 1 off each hard tank and front sac. I know my buddies 13 A22 is like this and my 16 A20 is the same. Do all 4 drain pumps run but nothing discharges? Which tanks/front bag isn't draining?
PostPosted: Tue Jun 27, 2017 2:09 pm
I think the rear right and the front are not filling,but when I hit drain I can hear them run
PostPosted: Tue Jun 27, 2017 2:36 pm
Can you hear the fill pumps running?
PostPosted: Tue Jun 27, 2017 7:35 pm
Yes when they drain I can hear them,when they fill I can't hear them
