It is currently Wed Oct 21, 2026 7:07 am
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
 Post subject: Re: problem starting
PostPosted: Thu Apr 05, 2012 7:47 am
I cannot see needing to replace cap wires and rotor at 100hrs? Maybe the plugs but not the other stuff. I would be at the dealership talking to someone or on the phone direct with Indmar. I will say mine does the same thing as far as the delayed start but it's not enough to warrant any work. I have 115hrs on mine and will be replacing that stuff this off season but in my own garage.
Good luck!!!!!
PostPosted: Thu Apr 05, 2012 10:13 am
Ya replacing all that stuff is an excuse to get your money, that should have been covered under warranty. I'm not surprised though, you use the same dealer that jacked up my prop seal, they will never again see my boat..........unless a miracle happens and they wake up, I'm not holding my breath
PostPosted: Thu Apr 05, 2012 10:28 am
If you ever have the boat in midland call me and we can hook it up to a fake a lake and I'll help you look at it, the extended crank is either fuel or spark, we just need to figure out which and what's causing it. I would stop out there at nasworthy but I usually go to Alan Henry.
PostPosted: Thu Apr 05, 2012 12:05 pm
Same here - mine does the same thing as far as the delayed start but it's not enough to warrant any work either. The 2012 ECMs have an autostart feature so you dont have to hold the key over (max started run time of 15sec). I wonder if Indmar has a tradeup program.
PostPosted: Thu Apr 05, 2012 12:30 pm
It may also just be the nature of the beast, you know the computer in these boats has one set program that doesn't rely on any O2 signal to run and the differences in barometric pressure and altitude play a significant role in how each starts and runs. A custom tune for your conditions may be what it takes to solve this issue. I'm curious if the catalyst models that do run O2's have similar cranking characteristics as the standard engine.....
PostPosted: Thu Apr 05, 2012 12:58 pm
If I had same spare cash, I would love to swap mine in for a 2012 with the LS3 to see if it also has this behavior ;-)
PostPosted: Thu Apr 05, 2012 2:10 pm
When Chattwake gets his maybe he can chime in
PostPosted: Sat Apr 07, 2012 11:05 pm
Walter wrote:
Has the service required light ever popped up on you?
No service or warning lights. It really seems like its not getting enough fuel at start? Ive tried different fuels--same..
PostPosted: Wed May 02, 2012 11:01 am
mine has done it from day one, sounds like typical gm fuel pump. i work in the auto industry and not saying they are the same thing but gm pumps are know for the check valves going bad causing long starts. it aggervated me at first but i think i read in the manual that it says you need to prime it a few times before you start it which tells me its normal for it to loose pressure. so as long as mine keeps starting (eventually) im going to let it be. and i always use the blower never turn it off unless im just hanging out. just my 2C
PostPosted: Wed May 02, 2012 12:26 pm
If you're around the lake on Saturday I'll stop by if I can find your place
