It is currently Tue Mar 24, 2026 2:36 am
 Post subject: New Owner Question(s)
PostPosted: Thu Apr 05, 2012 6:46 am
Out with the old and in with the NEW. I recently traded in our old"er" 2003 18ft Crownline for a brand new 2012 Axis A22. I will post some picture once we pick her up on Monday.
I do have a quick question, since I can't find any documentation...does the A22 have a way to report temperature and oil pressue. I don't rememeber seeing the specific gauges, but wanted to know if there was more than a warning light (if even that). After losing one engine in my past life, I have become accustomed to watching those pretty regularly.
Thank you to the forum...I have been reviewing this forum during my shopping/purchasing and you have helped my with my color and brand decisions. I also just purchased Hot Sauce in anticipation of taking care of all that BLACK.
Also does anybody have guidance on setting up a lift. I have a HydroHoist lift and I was going to pattern it as closely to the trailer as possible. Any wisdom here will be appriciated.
 Post subject: Re: New Owner Question(s)
PostPosted: Thu Apr 05, 2012 7:38 am
Yes there are gauges that let you monitor both those. Oil pressure,motor water temp, lake water temp, air temp, depth. Congrats.
PostPosted: Thu Apr 05, 2012 9:04 am
Are those all digital readouts on the one gauge...you page through them?
PostPosted: Thu Apr 05, 2012 9:16 am
Yes, It allows you to scroll throught them as and leave it on which ever you choose. I usually leave it on the depth just because I am so peronoid about hitting the prop or shaft on something. The system will definately alert you if something is not in check.
Actually I changed out my impeller two weeks ago and the first tim I put it back in the water the pressure side hose blew off and as soon as it started getting warm I had plenty of warning. The boat overall sems to have a good monitoring system for all potential hazards.
Thx
PostPosted: Thu Apr 05, 2012 12:12 pm
Agreed - the AXIS dash is well designed and simple. Even in a boat with dedicated gauges, the ECM is paying way closer attention than the driver ever would. I had an IO with full instruments before and all they ever did was kill your night vision (and burn out bulbs that were a pain to replace). Congrats on the new ride. I had considered a used Malibu and Mastercraft and the reliability of those "FANCY" dashes really scarred me.
Users browsing this forum: Google Adsense [Bot] and 106 guests
