It is currently Thu Nov 12, 2026 5:17 am
Post new topic Reply to topic  [ 12 posts ]  Go to page Previous  1, 2
 Post subject: Re: Ballast Tank Pump Failure
PostPosted: Wed Jun 14, 2017 8:16 pm
zenianth wrote:
They are failing. DEAD. No hum or blockage. Really hope this is the last one. It wasnt fun pulling the boat home with 1 side 100% filled with ballast plus a fatsac.
Why didn't you drain the full ballast bag by removing the fitting from the bag and letting it drain into the bilge and just drain out the rear drain plug?
PostPosted: Thu Jun 15, 2017 6:34 am
Are the 17s using the same aerator pumps as previous years. If so, they are really easy to work on. The cartridge (all mechanical and moving parts) are replaceable. And if you pull the cartridge on a drain pump you have removed the static plug that would be keeping any water in the tank. At minimum, like mentioned above, if you have a full bag you should drain it into the bilge immediately after putting it on the trailer instead of dragging home the weight.
________
