It is currently Tue Sep 22, 2026 9:22 pm
 Post subject: 2015 Axis A22 Depth Finder Location - Help Please!!
PostPosted: Wed Sep 07, 2016 6:37 pm
All, I ordered a depth finder transducer from Bakes and am needing to install it. My dilemma is i don't know where the stock location is on the 2015 A22. On previous models, it was on the starboard side next to the V-drive, but I'm seeing that the location may have changed to under the round access panel next to the driver seat on the 2015 models. Can anyone with a 2015 A22 comment on the location of their depth finder?
Thanks
 Post subject: Re: 2015 Axis A22 Depth Finder Location - Help Please!!
PostPosted: Wed Sep 07, 2016 9:28 pm
I was asking Bakes about a depth finder for my 2016 A20 and they provided a PDF instruction manual which told me exactly where to drill. Call or email them and get the instructions specific to your boat?
PostPosted: Thu Sep 08, 2016 4:57 pm
Thanks
My 15 a24 was under the round access panel.. find the plug first (I was stupid and did not) but I was able to extend the wires and it works fine.
PostPosted: Fri Mar 24, 2017 1:09 pm
Did you use 3M 5200 or 4200 to install your depth finders?
PostPosted: Fri Mar 24, 2017 6:58 pm
I think 5200 but either are fine..
PostPosted: Thu May 04, 2017 6:43 am
Where did you guys get the depth finder? Was it through-hull or glue down? As far as I can tell both are unavailable from Bakes:
http://www.bakesonline.com/detail.aspx?ID=1631
http://www.bakesonline.com/detail.aspx?ID=1635
And the dealers want $450 for them.
2015 T23, 350, High Altitude prop, FlyHigh front/rear pnp
PostPosted: Thu May 04, 2017 6:54 am
Screw in style.. call bakes ask for Andrew he will get you the right one for your boat.
PostPosted: Thu May 04, 2017 1:43 pm
Thanks!
