It is currently Thu Sep 24, 2026 6:53 pm
 Post subject: Cruise
PostPosted: Mon Apr 03, 2017 8:36 pm
2017 a20
We have paddle wheel only no zero off gps,
My 7 year old does not wakeboard very high speeds. I set cruise at 14.5 MPH and after cruise engaged the speed varied from 12.2 to 16 ish. Is this common or do I have a problem? If common does zero off preform better ( on lake ) and can you install or did it need to be bought when we ordered boat.
 Post subject: Re: Cruise
PostPosted: Mon Apr 03, 2017 9:11 pm
It is common for speed to fluctuate a bit with paddle wheel but not sure about 4 mph. I have a 16 A20 and added GPS cruise after the fact. The good thing about Axis is that everything is prewired. I bought the puck from my dealer, drilled the hole for the wire harness to go through and plugged it in. In the settings you can change from paddle wheel to GPS. Works so much better than paddle wheel in my opinion and holds speed.
PostPosted: Mon Apr 03, 2017 9:59 pm
Are you basing the 4mph off gps or off the dash speedo?
PostPosted: Tue Apr 04, 2017 5:00 am
Off of the dash speed, the speedometer
PostPosted: Tue Apr 04, 2017 5:01 am
Steve what was cost to add zero off?
PostPosted: Tue Apr 04, 2017 8:53 am
I could be wrong but if you are fluctuating that much I don't see how what input u use makes a difference. The cruise looks at in input signal and tries to hold it based off that. My paddle holds it within a mph easily when surfing.
PostPosted: Tue Apr 04, 2017 10:43 am
14.5 MPH is a very awkward speed. Unfortunately, you are basically halfway on plane and it's really hard for the boat to manage that. I'd bet at 18-19mph the problem would go away.
PostPosted: Tue Apr 04, 2017 12:56 pm
Higher speeds do seem better but still think should hold closer then that, am taking into dealer end of this week
PostPosted: Tue Apr 04, 2017 1:33 pm
I think you're wasting your time, but let us know what they say.
The best thing to do would be to get them to the point where you can go 16-17mph. That's still relatively low impact, and at that speed the wake might actually start to clean up so they can cross over the wake easier.
PostPosted: Tue Apr 04, 2017 2:07 pm
Or fill front ballast only.. worth a try imo.
Users browsing this forum: Google [Bot] and 92 guests
