It is currently Mon Nov 03, 2025 9:28 pm
 Post subject: New owner '16 T22, another plug and play question
PostPosted: Sat Oct 22, 2016 10:35 am
Sold my Supra 21v at end of sept. Brought home new '16 T22 Oct 1st. Getting everything dialed in and loving the new ride. Wake is so sick. Surf wave is fun and easy to set up.
I have installed the plug and play bags bow and rear. My question is about the rear plug and play. Is there a valve hidden somewhere to turn off the fill to the rear bags. If we want to just run the rear hard tanks is there a valve somewhere to stop the overflow to the plug and play bags. I've searched but haven't found one. Dealer is telling me that there is but they aren't sure where it is. Great answer right. Anyone know if there is a valve.
2016 T22
 Post subject: Re: New owner '16 T22, another plug and play question
PostPosted: Sat Oct 22, 2016 2:43 pm
Not that I'm aware of. A few years earlier models had the valves.
PostPosted: Sat Oct 22, 2016 2:58 pm
There are no valves, if you want to run hard tank's only just keep an eye on your sacs, as soon as they start to fill with water shut off your pumps. You will want to add some overflow/vent lines off those rear sacs also.
PostPosted: Sat Oct 22, 2016 3:05 pm
I own a 15 t22 and mine has valves just inside the rear lockers mounted on the inboard side. The handle is the only thing visible
PostPosted: Sat Oct 22, 2016 3:14 pm
I have a 15 T23 and I have valves that you can turn off to stop flow to the bags. Start at the bags and follow the in flow line backwards towards the hard tank and it should be there.
2015 T23
PostPosted: Sat Oct 22, 2016 3:46 pm
They got rid of the valves in 16
PostPosted: Sun Oct 23, 2016 7:45 am
Thanks for the replies. I'll stop searching. I might add some in line on the fill side.
2016 T22
PostPosted: Wed Oct 26, 2016 7:27 am
If you time the tanks before installing bags that is a great way to do it by time, I currently block by hand the drain and vent and make it overflow then turn off, that valve would be a life saver, it will come through the drain and the vent so im not sure 1valve would cut it. I didn't see one when I took off the cover in rear locker . If you could replug your vent and drain and time them(mine were 1:30 for left and 2:30 for right), that would be best way.
