It is currently Fri Oct 31, 2025 6:53 pm
 Post subject: Re: Wet Sounds Pro 485's or 3-Some system
PostPosted: Sun Apr 08, 2012 7:07 pm
The amps are set on high pass. No distortion and this is what was recommended to me. Everything I've read/hear about the Revs is that they like power. I've seen some running jl hd750/1 to each rev.
Here's my amp rack
PostPosted: Sun Apr 08, 2012 8:33 pm
To bad kicker class D amps are only low pass amps optimal 50hz-200hz. The jl amp is nice. Its one of the few class d amps they are high/low pass amps. Technology is much like a mono class AB amp.
Gibby
2011 A22 Vandall
PostPosted: Wed Oct 05, 2016 1:54 pm
Here's my amp rack
So, do you have some of the RCA's on splitters, since there are only 3 coming from the head unit? Also, noticed that the bottom ARC amp doesn't have any RCA's hooked up, is this an extra amp or was it just not hooked up in the pic. Clean set up, nice job. Abou to attempt something similar on mine.
2011 A20!!
