It is currently Tue Nov 04, 2025 4:35 pm
 Post subject: What's your top speed?
PostPosted: Fri Sep 30, 2016 4:40 pm
I have a 2016 A22 with the Monsoon 350 SS and the 1235, High altitude prop. My top speed is just under 33 mph, ballasts empty.
Seems I've heard of higher top speeds with the same set up. Maybe 38 to 40.
What's normal?
Thanks
 Post subject: Re: What's your top speed?
PostPosted: Fri Sep 30, 2016 5:58 pm
What's your elevation?
PostPosted: Fri Sep 30, 2016 7:19 pm
2016 T23 350 motor OJ945 prop also around 33mph.
PostPosted: Fri Sep 30, 2016 7:29 pm
I think it's the prop.
I had the 2249 and was at 38-40 top speed as well.
PostPosted: Fri Sep 30, 2016 8:24 pm
I'm at about 1100'.
Thanks for the responses
PostPosted: Fri Sep 30, 2016 8:27 pm
Pyromed1 wrote:
I'm at about 1100'.
Prop change.
Switch to the 2249 or 2247 and it will feel like an entirely new boat.
I started with the 1235 and was disappointed. Props mentioned above will up your top speed and operate much more efficiently.
PostPosted: Fri Sep 30, 2016 8:39 pm
Great! Thanks! Still decent low end for surfing?
PostPosted: Fri Sep 30, 2016 8:55 pm
My 15' A24 350 with the 2249 surfs well. 900's rear, horseshoe front and a 450 on top of the front seats. 1000' feet elevation. My top end is 36-38mph
PostPosted: Fri Sep 30, 2016 10:03 pm
That's our primary use of our 15 T22. Handles surf speed just fine. We run fly high 750's in the back and fly high bow bag under the front seats plus stock. I've had 12 in the boat with full ballast and never had a problem getting to surf speed. Need a few in the bow to run all that weight at wakeboard speeds.
PostPosted: Mon Oct 03, 2016 11:29 am
Stock prop on 2016 A20. Just above sea level. Base engine. Top speed: 37mph.
Users browsing this forum: No registered users and 79 guests
