It is currently Sun Sep 14, 2025 6:59 am
 Post subject: 2011 A20 Service required alarm at startup only
PostPosted: Mon Sep 26, 2016 1:03 pm
I have a 2011 A20 and I am getting the service required alarm at startup only. After a few minutes it goes away and does not come back on at all until the the next time we come out to the boat. It runs perfect and all of the gauges are within spec (i.e. temp, oil pressure), so I don't know if it is just like a reminder alarm like my cars oil change light or what. Also, i always turn the battery switch to the off position when we put the boat on the lift, not sure if that would have anything to do with it. Any help will be appreciated!!
2011 A20!!
 Post subject: Re: 2011 A20 Service required alarm at startup only
PostPosted: Mon Sep 26, 2016 5:27 pm
Sometimes happens to me. Not a "real" service required light if it doesn't require you to silence the alarm every 5 minutes. Just another little quirky axis thing. Mention it if you have it in the shop but I wouldn't make a separate trip for that.
PostPosted: Tue Sep 27, 2016 7:31 am
How do you silence it? Also, someone told me that I could go into settings and look at what code or what is causing it, do you know how to get into settings? My manual tells me how to adjust certain settings via toggle, but doesn't actually mention a setting menu perse. Thanks
2011 A20!!
