It is currently Fri Sep 25, 2026 5:31 pm
 Post subject: 2015 axis a22 draw in water depth????
PostPosted: Sat Sep 17, 2016 4:37 pm
Hi everyone
I need to pull my boat out.season is over in new
Hampshire.the water level on my lake are very low.
Can anyone tell me the lowest water I can safety go in?
I'm just concerned since the ramp is is very shallow about 4 feet.
Thank you
Awesome site I have learned so much !!!
 Post subject: Re: 2015 axis a22 draw in water depth????
PostPosted: Sat Sep 17, 2016 4:52 pm
The draft is 27 inches, so you should be fine. Don't wait around though. Spray some liquid rollers on your trailer bunks first though. It'll make loading A LOT easier.
PostPosted: Sat Sep 17, 2016 7:03 pm
Thank you
PostPosted: Sat Sep 17, 2016 9:41 pm
There is a sand bar between launch and lake at my cabin. Low water this spring had me nervous my depth finder said 1.4 feet but I made it.
PostPosted: Tue Sep 20, 2016 9:21 am
Surprised you didn't hit if your depth gauge said 1.4'! Anything under 2' on the depth gauge and I think you are getting very close to making contact.
 Post subject: 2" on depth guage is a lot more than 2" water depth
PostPosted: Tue Sep 20, 2016 12:32 pm
The depth gauge transducer is on the boat hull, which is already well below the water's surface. So it said there was about 17 inches below the transducer. The prop hangs down almost that far below the hull, so you were very close.
Wayne
PostPosted: Mon Sep 26, 2016 5:33 pm
I use my boat in all kinds of depths. When the gauge is reading 1-1.5 feet if I get out it's up to my thighs. Around 1.5 feet is where I start churning mud. If it's a rocky bottom I'd be very worried under 4 feet. If it's mud, less worried but how much fun can you have in 4 feet of water?
Users browsing this forum: No registered users and 111 guests
