It is currently Mon Jul 06, 2026 1:17 pm
 Post subject: Help, my surf gate won't extend.
PostPosted: Sun Aug 28, 2016 10:40 am
I'm on the water and when my wife turned around to get me after surfing, she got a left gate fault retracting. The gate is fully retracted on both sides. I have tried surf gate maintenance and calibration. I have turned off the batteries and restarted the engine multiple times. It says the gate is ready, but won't deploy on either side. Any help to save my day on the water would be great.
2014 A24 w/ LS3
 Post subject: Re: Help, my surf gate won't extend.
PostPosted: Sun Aug 28, 2016 10:41 am
By the way, it is a 2014 A24
2014 A24 w/ LS3
PostPosted: Sun Aug 28, 2016 11:36 am
Check the breakers, down by the drivers feet on the side panel
PostPosted: Sun Aug 28, 2016 11:40 am
I don't know how to help with the gate, but don't call it a day because of that. You can always just try the old school listing method to surf. :)
PostPosted: Sun Aug 28, 2016 12:40 pm
Breakers weren't popped. We are just hanging out on the water like a boring old pontoon. I guess I'll call the dealer tomorrow.
2014 A24 w/ LS3
PostPosted: Sun Aug 28, 2016 2:26 pm
This is when the wakeboard comes out then, but since my boat is at the factory and I was on a pontoon yesterday I know how you feel
PostPosted: Mon Aug 29, 2016 9:27 am
Not sure if you have this on your boat, but my T23 has this issue and it has always been the fuse running to the control box behind the motor. Should be a small flat orange fuse encased in a black rubber case that is attached to orange wires running to the surf gate. Pop the fuse out of the one that is not working and replace or just swap out the one on the other gate and this will retract the gate.
PostPosted: Mon Aug 29, 2016 1:14 pm
I talked to the dealer and he said to check the fuse that you ate talking about and to do a system reset. If that doesn't work, back to the dealer for warranty work.
2014 A24 w/ LS3
PostPosted: Wed Aug 31, 2016 12:42 pm
I had to replace the surfgate ram when I had that issue. Covered under warranty, but I suspect it will happen again.
