It is currently Sun Sep 27, 2026 11:39 pm
 Post subject: Satellite Radio Transmitter?
PostPosted: Tue Aug 09, 2016 12:42 pm
Does anyone know what satellite radio transmitter is used for the 2016 Axis T23?
2016 T23, 5.7L 350, 3093 Prop/15x12.5 w/ 165 cup, Wake Makers 825lbs PNP rear lockers, Sumo Sac 650lbs PNP, 2nd Ronix Eight.3 650LB bow, Ronix Eight.3 800LB Floor Bag
 Post subject: Re: Satellite Radio Transmitter?
PostPosted: Thu Aug 11, 2016 10:09 am
I emailed Kicker and they told me to use the SXV300 with the KMC20.
PostPosted: Thu Aug 11, 2016 3:21 pm
Awesome thanks! found great price on Ebay. I think around $40 with free shipping, brand new
PostPosted: Fri Aug 12, 2016 4:19 pm
I may add it as well. Let me know where you run the antenna and if the install is easy. Sounds like it simply plugs in otherwise.
PostPosted: Sun Aug 14, 2016 8:42 pm
Yes, keep us posted on this one
PostPosted: Tue Aug 16, 2016 12:46 pm
Does the transmitter plug into the "Kicker" brain box mounted next to the amps? I'm not seeing any connections behind the head unit itself.
thanks,
Nick
PostPosted: Tue Aug 16, 2016 7:00 pm
I installed the satellite radio transmitter tonight. I ended up mounting the antenna next to the trim left of the glove box. I then ran the wire under the trim into the glovebox. From there I drilled a hole in the far left of the glovebox, which allows the wire to run into the area with the amps. The hole had to be big enough to push the connection thru. From there I unscrewed the amp board and found the sat connection running Into the "brain".
