It is currently Thu Sep 10, 2026 10:35 am
nitrous1
Post subject: Re: Bow Bag Auto Draining and Bow Drain Pump Doesn't Work - Posted: Mon Aug 08, 2016 4:16 pm |
Joined: Thu Dec 03, 2015 8:54 am Posts: 86 Location: Higgins lake, Michigan
I was out today and noticed that if I don't vent the bag when filling, it doesn't siphon drain while using it, but for it to drain totally when your done you have to top off and vent then drain.
_________________ 2016 T22 409 Black/metallic yellow
alexandera
Post subject: Re: Bow Bag Auto Draining and Bow Drain Pump Doesn't Work - Posted: Fri Aug 12, 2016 7:27 am |
My bag siphons out the fill pump too; even past the check valve. Waiting for winter to "dooshay engineer" an improved solution.
The negative pressure on the fill side is much stronger than the factory CV can handle.
_________________ -aha-
Users browsing this forum: No registered users and 20 guests |
