It is currently Mon Oct 12, 2026 2:53 pm
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
 Post subject: Re: 4" Seat Riser GROUPBUY
PostPosted: Fri Jul 29, 2016 11:57 am
When attaching the seat to the riser, I took the fixed panel off so it was easier to get nuts on the studs. It comes off with 4 hex screws.
2013 A22 Black/Orange - SOLD
PostPosted: Fri Jul 29, 2016 3:08 pm
I doubt you will think it is too high. My wife is 5'7 and she loves it. We don't even use the booster anymore.
PostPosted: Sat Jul 30, 2016 12:57 pm
Awesome! I am 5'11 and the hubs is 6'5". So we are both pretty tall, and it still is too short...even with the bolster. Come on Axis/Malibu...get your crap together!
2018 T22
PostPosted: Sat Jul 30, 2016 1:28 pm
Lol. You are outside of the standard deviations.
PostPosted: Sat Jul 30, 2016 6:07 pm
Raime do you guys run bow weight?
PostPosted: Sat Jul 30, 2016 7:23 pm
Yup. The p-n-p bag until the seat rises and I usually throw a 350lb bag in the walkway if we are low on people. I have the 750s in the rear and run with the wedge.
I got it installed this afternoon, but didn't get a chance to use it. Tomorrow morning will be the test! Overall first impressions are that it would be nice if it was a little less for clearance to the steering wheel and overall comfort, but I am not going to pass judgement until we get to test it out towing.
2018 T22
PostPosted: Tue Aug 02, 2016 7:19 am
So, I got the seat riser installed. Thanks for all the tips on the install!
Overall, I like it. I think it could be 3" instead of 4 though. That would make it a bit harder to install though. I might have my brother modify the box over winter, but for now, it's better than it was. My hubs hates it, but he typically only drives for me.
One unintended consequence was that now my mirror isn't high enough. I have the mirror mounted on the drivers window over to the left. Has anyone else had this issue? What did you do to solve? PTM sells a 4" extension for the bracket, but it's $100....so my seat riser project is getting pretty pricy!
2018 T22
PostPosted: Tue Aug 02, 2016 7:55 am
YES! we had the same issue with the mirror. I moved it to the observers side. And then still had an issue adjusting it to see more that the sun pad. I asked PTM why I couldn't adjust it more. They suggested flipping the mirror upside down, which will give you more "tilt" on the mirror. That totally worked.
PostPosted: Tue Aug 02, 2016 10:54 am
Ok cool. I will try that this weekend before I shell out another $100...
2018 T22
PostPosted: Tue Aug 02, 2016 2:05 pm
I too flipped my mirror mount even before I installed the riser, now it's still perfect on the port side window.
