It is currently Sat Oct 31, 2026 4:33 am
 Post subject: 2011 Axis Vandal A22
PostPosted: Wed Jul 27, 2016 11:19 am
Hi - looking for advice on surf setup. Bought a used 2011 A22 Vandal. Wave seems Frothy with not a lot of push. Currently fill front, mid and right rear (for goofy) and a 400-500 pound bag on the floor behind driver. Wave is surf able but not a lot of curl or push. Don't use wedge as it seems to make it worse. Guessing the bags are whatever came with vandal from factory. Not sure on weight. Was told 750/side including hard tank. Thoughts ?
 Post subject: Re: 2011 Axis Vandal A22
PostPosted: Wed Jul 27, 2016 11:25 am
Surf gates?
PostPosted: Wed Jul 27, 2016 11:40 am
Congrats on the purchase. How fast are you going with that setup?
If you look over the below threads there are a number of DIY or purchase options that will allow you to weight your boat evenly (both rear tanks full).
viewtopic.php?f=16&t=3641
viewtopic.php?f=16&t=3823
viewtopic.php?f=16&t=1997
PostPosted: Wed Jul 27, 2016 1:21 pm
No surf gates and speed is typically 10.8 - will try a DIY and see what happens - thx. Also, is the wedge supposed to lock in the down position?
PostPosted: Wed Jul 27, 2016 1:28 pm
No. Axis wedges are free floating and find "their optimum" spot.
PostPosted: Wed Jul 27, 2016 2:10 pm
You could probably stand a little more bow weight if possible also.
PostPosted: Wed Jul 27, 2016 4:46 pm
Get rid of your 1st generation platform and get the 2nd generation one for 2012-2013 Axis boats.
PostPosted: Wed Jul 27, 2016 5:16 pm
I have a 2011 a22 vandal. I fill all ballets as full as you can get. Poor mans gate on plate form. But this up graded to mission delta. Both work great. Lots of push. Clean no wash. Poor mans gate good with some extra weight in nose with people or bag on seat. Mission delta all people in cabin. Wife just my wife in the boat driving I have lots of push. Also run with wedge down. 11.6 on the speed. And I have the old platform. Not the newer one.
PostPosted: Wed Jul 27, 2016 5:27 pm
Thanks guys - looks like I will try building a gate
PostPosted: Wed Jul 27, 2016 5:28 pm
I have one for regular side. Are you surfing regular or goofy?
