It is currently Tue Jul 07, 2026 9:32 pm
 Post subject: 2015 A22 depth finder install part #
PostPosted: Wed Jul 27, 2016 7:55 am
I'm looking to Install a depth finder on my 2015 A22. Can anyone tell me what the part number is? Or have a picture of it? Also where is it located and where is the plug in point? Any help is appreciated.
 Post subject: Re: 2015 A22 depth finder install part #
PostPosted: Wed Jul 27, 2016 9:28 am
Call bakes they can hook you up on it. On my 15 a24 the plug was in the center access point in front of the gas tank. It could be there or in the rear compartment next to transmission. Find the plug before you drill.. very easy to install took under an hour.
PostPosted: Wed Jul 27, 2016 9:44 am
Did you just plug it in and it worked?
PostPosted: Wed Jul 27, 2016 10:12 am
Yup very easy
PostPosted: Wed Jul 27, 2016 10:50 am
In case it's not clear you do have to drill through the hull and use adhesive to set the sensor.
PostPosted: Wed Jul 27, 2016 10:52 am
How big is the hole and where is it located in the hull on a 2015 A22.
PostPosted: Wed Jul 27, 2016 11:08 am
Yes you do.. I used 3m 5200
PostPosted: Wed Jul 27, 2016 11:11 am
You have to drill the hole.. I don't recall the exact size but something like 2 inches. When you get the sensor just measure it and buy a whole saw at your local hardware store. I used magnets (one on the inside and one on the outside of hull) to make sure I didn't interfere with anything else. Also make sure and chamfer the hole so you don't get stress cracks. Really this is a very easy project to do.
PostPosted: Wed Jul 27, 2016 11:12 am
I would put the hole wherever your plug is.
PostPosted: Tue Aug 02, 2016 10:47 am
Can anyone with a 2015 tell me where their depth sensor is located? In my 11 it was next to the VDrive unit. Just wondering if that changed.
Users browsing this forum: Majestic-12 [Bot] and 37 guests
