It is currently Wed Nov 12, 2025 2:05 pm
 Post subject: Re: prop recommendation 2013 A20
PostPosted: Tue Jul 19, 2016 5:01 pm
doing a little comparing, looks like the 1235 is the same pitch as the 2247, just a 1/2" smaller diameter. is it actually worth having the extra diameter?
PostPosted: Tue Jul 19, 2016 11:25 pm
For pushing big weights you need the bigger diameter. It helps with holding speeds and also acceleration. You will be pushing more water...so likely you will need to change pitch to make sure you hit your desired RPM's while using it.
2015 T23 - Sold
2018 ???
PostPosted: Thu Jul 21, 2016 7:53 pm
i think i have decided to go with the OJ 945, thanks for the help guys!
PostPosted: Thu Jul 21, 2016 8:57 pm
Good choice. I may be a little bias cause Eric at OJ gave me a tour of the facility but honestly, tour or no tour I try to keep my engineering mind biased free. From my experience, the acme props ding up easier than the oj props. I swear I have chopped small logs with the oj and it had no damage. The acme not so much. Both perform as designed. The oj feels a little less vibration in my opinion. Beyond that, I own both the 2315 and oj945. Get whichever is cheaper.
PostPosted: Fri Jul 22, 2016 10:41 am
the oj being more durable is what swayed me. i boat in the river and it can get shallow, so the more durable the better! the acme is $30 cheaper, at that point its too low to matter.
PostPosted: Sun Jul 24, 2016 3:48 am
Ran the 2315 yesterday for the first time. Feels great! Hit 38 mph unloaded.
