It is currently Fri Oct 30, 2026 5:53 am
 Post subject: Re: A22 Steering Cable Length
PostPosted: Mon Jul 18, 2016 8:15 pm
Sweet thanks. I have same boat and steering is getting a little tough when surfing.
PostPosted: Mon Jul 18, 2016 10:42 pm
So is your steering improved with the cable replacement or do you possibly have some other issue causing steering difficulty?
 Post subject: A22 Steering Cable Length
PostPosted: Tue Jul 19, 2016 3:39 am
Yes, it's back to "one finger" steering ability with zero friction. It had become a workout to turn the wheel. If your steering has become tight, you can disconnect the cable from the rudder arm to determine if it's the cable or the rudder box housing.
PostPosted: Tue Jul 19, 2016 10:13 am
That makes sense and an easy way to isolate the issue. Mine is a '16 A20 with 70hrs and so far no steering issues.
