It is currently Tue Nov 10, 2026 8:48 am
 Post subject: Re: 2016 Rear ballast bags for Axis boats
PostPosted: Mon Jul 18, 2016 12:13 pm
I would love to hear more about these new WakeMaker 825 rear ballast bags. I just finished my 20 hour break in on a 2016 T23 and am trying to figure out ballast setups. Wakemakers is pushing me hard on these 825, but I cannot find anyone who has used them.
PostPosted: Tue Jul 19, 2016 4:54 am
I have the 825s on my '16 a20 and like them.... Cheaper than bfi 750s
PostPosted: Tue Jul 19, 2016 4:29 pm
I have a 2016 Axis T23, and I purchased the wake makers 825 bags for the rear and sumo 650 for the front. Still need to do more testing. I ran all the factory tanks and the pnp full, wedge down, driver and spotter and large guy surfing and seemed hard to get on plane. Going to try without wedge first then with additional weight in bow. Any suggestions would be appreciated.
2016 T23, 5.7L 350, 3093 Prop/15x12.5 w/ 165 cup, Wake Makers 825lbs PNP rear lockers, Sumo Sac 650lbs PNP, 2nd Ronix Eight.3 650LB bow, Ronix Eight.3 800LB Floor Bag
PostPosted: Tue Jul 19, 2016 4:34 pm
I've got the exact same setup, I can get to surf speed, 11.2, fine but it struggled to get to wakeboard speeds. Talking greater than 30 seconds and that was without the wedge that time. I'm running the 2419 prop on mine. I'm thinking about changing to the 2773 however because that should put that RPM on takeoff in the 4k range which is the highest torque on the 350. I think it's a little too high right now and doesn't have the torque available.
PostPosted: Tue Jul 19, 2016 4:52 pm
Are you having any issues with the sumo sack up front not completely draining? Is this normal? When installing I disconnected the plastic factory Y splitter and ran the fill to the upper port on the bag and the other two tubes to the corner drains on each of the back corners. This sound correct??
PostPosted: Tue Jul 19, 2016 8:37 pm
No, I put the line with the check value, which happened to be the fill on the port side, then the vent on the top, and then drain on starboard side. Mine drains pretty flat.
PostPosted: Tue Jul 19, 2016 10:14 pm
Mine is just like 80AMT23 with the plumbing. Top vent, port fill, starboard drain. It doesn't drain very well unless you switch toggle to empty and then accelerate to surf speed to get bow in the air. Even then it still has several gallons of water in it when done.
2015 T23 - Sold
2018 ???
PostPosted: Thu Jul 21, 2016 3:06 pm
I've got a 2015 A22 but we run 1100s as full as we can get them with 650 sumo in the front. I also ALWAYS grab my extra 550 bag and put it in the front middle as far forward as possible. Even with the wedge it was no problem getting on plane.
The 350 with the 2015+ transmission ratio should get you on plane without issue. Try some more bow weight.
PostPosted: Sat Jan 21, 2017 12:09 pm
With the 1100's in your A22 and getting them as full as you can, does it put a lot of bowing on the engine dividers? Also do you have to move the bag around or will the water fill out the bag in locker?
2017 A22
2000 Sunsetter Lxi
PostPosted: Sat Jan 21, 2017 7:55 pm
You will have to reinforce the engine dividers I did some aluminum c channel from lowes
Users browsing this forum: Google [Bot] and 22 guests
