It is currently Thu Sep 10, 2026 5:32 am
 Post subject: prop recommendation 2013 A20
PostPosted: Sun Jul 03, 2016 3:43 pm
i have a 2013 a20. has a 5 blade OJ on it from when i bought it new, stamped oj 1936 tz-x5. also have the base moonson 350 motor. its getting pretty dinged up so its time for a new one. i have been looking at the wake makers chart https://www.wakemakers.com/axis-wakeboa ... propellers thinking about the acme 2247 but haven't seen much about it. i am usually only running the hard tanks filled but occasionally will run a 600 in each locker and a 650 in the bow. we also will cruise around with no ballast too. with the current prop it takes a long time to get on plane weighted down so looking for a better option and i don't want to kill cruising. open to suggestions, thanks!
 Post subject: Re: prop recommendation 2013 A20
PostPosted: Mon Jul 11, 2016 12:54 pm
No one?
PostPosted: Mon Jul 11, 2016 1:09 pm
I have the same boat and run the 1235. 750's in rear with whatever the bow bag is and have no problem surfing or wakeboarding loaded up. Usually 3 adults and 3 kids but have had a lot more as well. Hope this helps. There are surely many other options but it works for us.
PostPosted: Mon Jul 11, 2016 1:11 pm
I really like the OJ props over Acme. I run the 937 but it is for more heavy weights. Call them up and they will hook you up with what you need. Also a 1235 acme would work great for your boat it's a great all around prop. You can find some 1235's around at good deals I actually have one with I few dings and runs great if interested.
PostPosted: Mon Jul 11, 2016 4:38 pm
X2 I really like my 948
PostPosted: Mon Jul 11, 2016 5:30 pm
ACME 2079 is what was recomended a few years ago for the a20's pulling heavy weight. Same specs as the 2315 but .5" smaller in diamater. Its what I run on my 2013 a20, it will get most everything up on plane, regularly run with factory ballast, 750's in the lockers, nose sack, and a sack siting in the bow plus the wedge.
2013 A20
PostPosted: Mon Jul 11, 2016 8:28 pm
I'm switching from a 2079 to a 2315.
PostPosted: Tue Jul 12, 2016 12:53 pm
I run a 2313. Very similar to a 2315, just supposed to sacrifice a bit of tug for a bit of top speed. You have a lot of options to choose from. Assuming you aren't at a crazy elevation you should be able to choose one of the many and get on plane much quicker.
________
PostPosted: Tue Jul 12, 2016 3:11 pm
Thanks for the input. I'm in florida, so its sea level for me.
PostPosted: Tue Jul 12, 2016 5:52 pm
I have the exact same boat as you, at 5000' I use the 1235 and it is great. I've heard that is the prop for our elevation so not sure how it'd be for you.
