It is currently Thu Oct 29, 2026 5:35 am
 Post subject: Re: Anyone have to replace engine tray?
PostPosted: Tue Jun 14, 2016 7:29 pm
The reason it breaks so easy is cause of bad design. On the rear part of the locker, the tray doesn't rest on the side braces. It only rest on the front and back support. It is prone to break cause it doesn't have side supports where the dividers are attached. It is a simple engineering fix that has proven costly for owners.
PostPosted: Tue Jun 14, 2016 7:30 pm
Mine sits down around the whole thing I'm pretty sure. I'll look again to confirm though.
PostPosted: Mon Jun 27, 2016 1:19 pm
ImageImageImageImageImageImageImagemine's new and I'm completely rebuilding it from scratch. 12 millimetre hd-pe welded. Stainless hinges and gas shocks to follow. Half of the tray will be walk-through with level lid.
Sent from my HTC Desire 526G dual sim using Tapatalk
PostPosted: Fri Jul 01, 2016 4:35 am
PostPosted: Fri Jul 01, 2016 1:45 pm
Nice. I find the tray to be very shallow, yours looks like it would fit more than one and a half life jackets.
PostPosted: Fri Jul 01, 2016 2:33 pm
When I went to check the oil the other day I found another crack, right where the drain hose is attached in the back corner. Looks like the material is really really thin there, no wonder it cracked. Hopefully next week I'll get my aluminum one done.
