It is currently Fri Oct 30, 2026 7:38 pm
 Post subject: Surf gate won't deploy
PostPosted: Tue Jun 28, 2016 7:19 pm
My surf gate won't deploy on my 2014 a20. The surf gate is enabled in the setup but neither side will deploy. I'm going the correct speed for the surf gate to deploy. It use to work and now nothing. Is there a way to reset the system or fuses i should check?
2014 A20
 Post subject: Re: Surf gate won't deploy
PostPosted: Tue Jun 28, 2016 8:18 pm
Check the fuses
PostPosted: Tue Jun 28, 2016 9:26 pm
I've checked the breakers at the helm and none are tripped. I have also checked every fuse in the fuse box above the transmission. Is there another fuse box somewhere?
2014 A20
PostPosted: Wed Jun 29, 2016 10:10 am
I had the same problem. Dealer replaced a limit switch on one of the actuators.
PostPosted: Wed Jun 29, 2016 4:52 pm
Go into the setup on the dash display and see if they deploy when you put it in maintenance mode.
PostPosted: Wed Jun 29, 2016 9:30 pm
No luck in service mode. I hate going to the dealer. Every time I'm there they give me conflicting information. I just picked up my boat for its 20 hour service, a bent seat bracket, broken trans dip stick, & a 12v outlet that won't work. It took them 3 1/2 weeks. They assured me everything was working. The dip stick is still broke and the 12v outlet stopped working again and now the surf gate. I called the dealer and talked to their service tech and he told me to absolutely not put it into service mode. He also said they don't have a lot of service info on the surf gate to trouble shoot. Sorry about the rant. Thanks for the help. I guess it's back to the dealer
2014 A20
PostPosted: Thu Jun 30, 2016 4:40 am
I assume you checked the fuse panel as well? Could save you a big trip/headache for something small.
Toy Store:
2016 A22 Green/White
2009 Built Jeep Wrangler
1978 Bandit Trans-Am
PostPosted: Thu Jun 30, 2016 8:54 am
The fuse box I checked above the trans did not have a fuse labeled for the surf gate. There were 3 relays and about 5-6 fuses if I remember correctly. Is there an inline fuse somewhere? Also my surf gate gauge looks different than before. I do not have the black surf box as shown in this photo. It use to when it was working
2014 A20
PostPosted: Thu Jun 30, 2016 9:10 am
I believe the fuse box I looked at was engine related only
2014 A20
PostPosted: Thu Jun 30, 2016 1:13 pm
If you don't have that black display box where does it tell you on the dash that your gate is deployed?
