It is currently Thu Nov 27, 2025 3:03 am
 Post subject: 2015 A20 Front PNP Ballast?
PostPosted: Thu Apr 28, 2016 8:44 am
Ok, I am sorry to ask this, but maybe I am just missing it.
Are the front hoses WAY up in the nose? I poked around up there and didn't find anything. Really the only hoses I see in the front are farther back towards the drivers seat and then head toward the starboard side, do I just need to look harder?
Thanks in advance!
 Post subject: Re: 2015 A20 Front PNP Ballast?
PostPosted: Thu Apr 28, 2016 12:36 pm
Check if this video answers your question. It helped me setup the front sac in my A22. https://www.youtube.com/watch?v=YaSvnu8J2Yo
 Post subject: Still can't find it...
PostPosted: Wed Jun 08, 2016 2:26 pm
Ok, so I finally got in the boat and looked all over the nose. I have no hoses that look like the video posted. The only hoses I see is a "y" that is under the walk through seat...
Does that sound correct?
PostPosted: Wed Jun 08, 2016 5:46 pm
I'm not sure on an A20 but on my T22 the bow lines were connected with a "y" so if someone flipped the switch it wouldn't flood the boat. You just remove the y and you have a fill/drain/vent.
 Post subject: Hmm.
PostPosted: Wed Jun 08, 2016 7:22 pm
Maybe this would be an easier way...Was everybody's front PNP in the bow under the very front seat?
I have no hoses in the bow, only some under walkthrough seat at a "y" then they head to the drivers side.
PostPosted: Thu Jun 09, 2016 4:38 pm
That y is the fusion of your fill and drain connected to I believe your vent of your "front" pnp. This is so if you turn it on it does not flood boat. One piece coming from rear has check valve that is your fill, 2nd hose from rear of locker your drain. I (dealer with a warranty repair for leaking overflow during operation- never fixed that issue but relocation was on factory)relocated my vent to the side wall by driver foot well(maybe a mistake) so I can't remember where your vent leads to. We also moved fill line to same location in foot well instead of rear bottom of locker sharing binding space on mushroom bag. The mushroom bag when really full tests those plastic high flow connecters and the plastic threaded bag ports. In rears to stop hose kinking we moved valves to a 90 change to straight up and down in the outside front corners of lockers with handles stuck sort of in on position-installed a 90 elbow from Lowes plumbing (again on warranty cause kinking issue ). And drain cut to barely sticking out of box and bottom vent cut to bag vent hole placement I imagined when full. I cut hose lengths in rear lockers and installed quick connect high flows from wakemakers in all three lockers , dealer solved kink by rotating valve and installing 90. For days we could go on, but that front compartment (I have chillax seat making it a bit more complicated cause chillax hardware
750'rears well burped
950 mushroom well burped
Full fuel
Wedge
Stock ballast
And wife and batteries and ice chest is our setup minimum
The wife on wave Sunday iPhone high def full screen she is 5 3" and stays away from boat and this is 80% magnification
https://www.facebook.com/daves.wakeboat ... 812466861/
I'm tired of all the typing this is going to take . Know this well. Based upon your your question I can help you more on phone. 504-430-2563
 Post subject: Re: Still can't find it...
PostPosted: Thu Jun 09, 2016 4:47 pm
Forgot to quote you, your answer above, that's your front pnp closed system before install if bag and connections
PostPosted: Sun Jun 12, 2016 2:10 pm
I want to thank Grandaddy55 for the advice and pictures he sent me, they helped a lot.
With the 2015 A20 I had to plumb into the "y" and now have the 950 filling in front! Stoked.
I am having the bow bag drain though, I need to get that figured out...
PostPosted: Mon Jun 13, 2016 9:03 am
Great, great surfing coming, run pump until you install that fill check valve. Vent issue some use wine corks .
Users browsing this forum: Google [Bot] and 62 guests
